1 - 2 of 2 Posts
If I cut 7-8" of each end of factory side steps/rails of a rodeo to shorten them will the mounts still line up to the factory mounting points? If I try and put them On an amigo/rodeo sport?
Basicly... If I placed on the ground.. 1 factory step from a rodeo and 1 from amigo would the mounting tabs be in the same spot? So I would be able to just cut them shorter equally on each end and stick back on the plastic end caps and install? Or...... Is this idea toast.
1 - 2 of 2 Posts
