1 - 20 of 39 Posts
Well my rear bumper is kind of jacked up right now and I am tossing the idea around of making my own rear bumper. I am wanting a really basic bumper design with two tow points with the possibility of adding a tow hitch later on.
It would be pretty much the same as this one from Indy4x:
I am thinking a 4 inch by 2 inch rectangular piece of steel that I would weld caps over on the end and then mount it. I think a 6x2 would be too wide but I would need to take some measurements. Also wondering what wall thickness I would need...1/4 inch is a bit much? Wall thickness is my biggest question.
I am not ready to build this yet, just looking for some ideas, anyone do something this basic? Or if someone has a drivers bumper end cap they want to get rid of ;) I will take that temporarily until i build this.
Feel free to post up your custom rear bumper set-ups.
Looks like you have a good plan, that's the start.
I think the bumper you listed would look best on a pickup or Trooper, guess it depends on the look you are going for. For a Passport you might consider some side plates to tie into the existing body contours plus the added protection they'll provide.
That bumper is actually for a Trooper. I really like basic designs though, could add on some little extensions later on but it would mainly be for looks. I am mainly interested in trails and overlanding, not too in to crawling so I think a basic rear bumper for towing and be snatched out is the most important.
Well found three pieces of steel, 4x4 1/4 inch thickness. I think it is way overkill for a rear bumper on the passport not to mention it weighs a ton. Think I may try and take it in to the steel shop and have them swap my for a 4x2 in a thinner gauge metal. This could be the beginnings of a rear bumper for me!
This was how I ended up doing my bumpers I had found a pic of one similar on the web and went from there. I used I want to say 6x6 so I could do the cut outs for the tire and license plate.
This is my own design for the front bumper it's 1/8 in. To keep it lighter
I still am not happy with the mount systom it's probly not strong enough for my winch :( I just don't wanna mess up the frame.
Good job on that trooper bumper lots of work involved!!!
I used 3"x6" 1/4" on my bumper. It does double duty as an airtank for my ARB locker and tires. Also supports my swing out tire carrier / gas can.
That is a really nice size, that is essentially what I want mine to look like minus swing out carrier. I am re-thinking the 2x4 size now. Do you think the 1/4 inch thickness is a good fit for the rear bumper?
After both my rear doors started stress cracking. I had to get the weight off the doors. And yes 1/4" doesn't seem like overkill, it has taken some hard hits with only minor dents.
I forgot to mention the thicknes of my rear bumper material I went the next avalable thickness down from 1/4" to 3/16" it's still stout and it saved on extra weight. I can still pull it off myself lol. That's another cool bumper design on your trooper. Did you Do a front one??
I think I would like to go with 3/16...seems like a good in between size. I also want my bumper to be the weak link, not my frame. My thoughts are if I do go that thick, if it hits something really hard then it would crumple the frame before the bumper.
Twits kind of a catch twenty two strong for off roading yet can take a hit. I got hit in my old amigo (rearended) and it bent the bumper and sheered the bolts. Didn't hurt the frame. I fixed the bumper with a big trackhoe pushed it back lol. It was channel with another plate below and it still bent.
How much air are you able to put in there? What kind of pressure do you hold? Enough to fill up a flat tire? I have seen more of this recently and it really interests me, I dont plan on putting onboard air on anytime soon but for the future might as well plan right.
Bumper air tank holds about 4 gallons. I have a Viair 450c continuous duty mounted under the hood, it does and awesome job on 35" tires.
I build my front bumper too, cut up a old bumper to make it look better. Easy to remove for more serious obstacles :D
^ pre SAS
Well I am just going to use the 4x4 1/4 inch thick steel I have. I just need to figure out how I want to do it. I have two options:
A: I can make it more inboard by recessing it in between the rear points on the rear quarters. I really like this idea and it would really keep it slim and the weight down. The only con I can see to this is that it wouldnt protect the rear quarter panels. It would also be easy to just weld to the frame horns in a few spots. This way it wouldnt stick out a lot and would mean less leverage for a future receiver hitch.
B: Extend it out a few inches from the rear which would mean it would probably stick out two inches further than the stock bumper and cover the rear quarter panels. I think this would look bulky and add on an extra foot to foot and a half of material. Ill use paint to show you guys what I am thinking...
Discussion Starter · #18 ·
Here are the two lengths I am thinking of.
A is red and B is blue. This is just to show lengths of the bumpers. Obviously blue will need to be more outboard.
I guess the primary purpose of this bumper would be to have a strong recovery point and for a future receiver hitch point. Not too much for protection but that would be a bonus.
After smashing out two sets of tail lights on my 91 amigo :shock: I opted for corner protection... :D I don't like crunch sounds very much !!! There usually followed by a few choice words of cursing lol.... :x
Discussion Starter · #20 ·
I really like the bumper you have but I dont have the fab skills to do that and also just want to use what I already have. Maybe I should make it longer but also angle cut it kind of like \_______/ That would give a little extra protection I think. I wish I knew how to weld better. I dont trust my welds to mount this bumper, going to have to pay someone to do it.
1 - 20 of 39 Posts
