I'm pretty sure that the Isuzu Axiom is the only other vehicle that uses the same rack as the second gen Rodeos, Passports, and Amigos.jwood1016 said:Any one know of any carmakers that use a similar or same rack and pinion as Isuzu??
Im having the hardest time trying to locate some power steering lines!!! :evil:beagler said:I'm pretty sure that the Isuzu Axiom is the only other vehicle that uses the same rack as the second gen Rodeos, Passports, and Amigos.jwood1016 said:Any one know of any carmakers that use a similar or same rack and pinion as Isuzu??
I'll tell you, though, as soon as Joe Darlington comes up with a better steering setup than the stock rack and pinion, I'd like to take mine out and put in something more stout. I've heard that he's working on something since that rack has been such a weak spot on these rigs.
Sorry man, I thought that you were just replacing the rack. Which line(s) do you need, and what's wrong with the one(s) in your Amigo?jwood1016 said:Im having the hardest time trying to locate some power steering lines!!! :evil:
This probably wouldn't sit well with your parents, but if you look hard enough on craigslist, sometimes you can come across a whole Amigo or Rodeo with a busted engine or transmission for that much. Then you'll have all the spare parts you need when things break off-road.jwood1016 said:a new rack and pinion cost like 4 or 500 dollars.
