It shouldn't be 'whining'.
If you haven't had it that long, I would HIGHLY recommend 'zeroing' all of the fluids - this means replacing EVERY thing that has a lubricant/coolant.
>Trannie - 30W Motor Oil - *27mm bolt on pass-side of trannie -
Check immediately before driving again* You should EITHER have fluid run out when you remove the bolt OR, be able to touch fluid by sticking you finger in the hole - If neither of these produces fluid - your trannie is low and may be oil starved - causing the whining!!! :shock: NOTE: Open end wrench works best and when the trannie is warm - NOT HOT!!! I usually have to place the wrench, then go around and reach in from the front and pull HARD (truck in gear of course/e-brake on :lol: ) to 'break' loose the bolt.
>X-fer case - 30W Motor Oil
>Engine Oil - 10W30
>Radiator fluid including flush
>Front Diff - 80W gear oil
>Read Diff - 80 W gear oil
>Power Steering Pump - PW Steering Fluid -
* Also check to make sure full and not the source of your whining symptom*
Brake Fluid - DOT fluid - have it reverse flushed if at all possible from all 4 wheels
>Clutch Fluid - I would HIGHLY recommend, if the clutch is mechanically working, to have the slave, and valve dampener (valve on the fender well) replaced, and master cylinder either replaced or rebuilt and the system fluid replaced with new. As the hydraulic fluid ages, and contaminants build up, they settle in the slave cylinder on the trannie and it will eventually fail. If your Troop has been the SE for most of its life, and its as old as mine - guaranteed it close to needing a refurb - and I'm in the process of planning to replace the clutch mechanicals inside the trannie soon.
Knock these items out in as short an order as possible, documenting each one and the mileage/date - that way you'll be 'zero-timing' (pilot-speak) the fluids so you KNOW their status, not what someone told you.
Welcome to the Trooper Family
Cheers,
