shoestring said:
i don't know and if it did where would it be ?under the dash,under the truck,thats why i thought i'd ask first,just don't want to screw it up.also ,is it possible to move the drivers seat back anymore,just to big,lol
ok here it goes
Pedal height is measured from the top of the pedal to the floor
to check pedal freeplay measure the distance from the natural resting place to which resitance is felt( with your hand not foot)
on cable -operated models adjust the cable to achieve the spedified play between the nut and rubber cushion
pedal free play is around 3/4 "
pedal height 7 "
on most models, (hydraulic) , the freee play is adjusted by turning the clutch switch or stopper bolt. on later models with adjustable clutch master cylinderpushrods, loosen the locknut on the pushrod tunr the pushrod to achieve the proper freeplay, then retighten the locknut
on cruise control equipped models, turn the clutch switch until the plunger is fully retracted against the clutch pedal arm, then back out a half turn before tightening the locknut,
on non-cruise ctrl equipped models , turn the stopper bolt in until it just contacts the arm and tighten the locknut
Happy thanksgiving!
