1 - 4 of 4 Posts
found this out by crossing pins 4 and 6 and read the flashing light.
I believe this is to do with the EGR system. I have removed it all and cleaned it, but it did look to be ok anyway. However code 32 still showing and light shows Intermittently.
I've swapped the EVRV solenoid for one off my m8's trooper which has no faults and even with that solenoid the CEL shows and the code is 32 :?
Any ideas what wires to check for breaks or lose connections.
Isuzu bighorn "trooper" 3.1 td 97 auto lwb.
I just did some EGR system work. Changed a VSV valve on a toyota. The biggest thing I found was that there was a lot of clogged passage ways. Some tuff to get to or see. This may be the problem. Good luck
1 - 4 of 4 Posts
