It’s a 2.6L 2nd with 189k miles on it.
Okay now that I’ve got the alternator installed, I’m finally able to drive it.
I’m getting a rough idle, especially with the AC on which would be normal I suppose. It sounds rather loud rough. I don’t remember my 92 sounding like it, but it’s been a long time since I’ve owned that one.
im having the check engine light come on when it gets to around 40mph, although it has come on earlier depending on the rpms it looks like, not necessarily the speed. The light doesn’t flash, it just comes on and stays, but goes off when I change to a higher gear or slow down a little. (I.e. 4th to 5th gear)
i have not changed the spark plugs, but could this possibly be a cause of this issue?
is there any other issue that may be causing this? This vehicle had been sitting for 6-7 years before I got it. I have since changed the oil and replaced the slave cylinder and alternator.
Any other things to look into would be good to know.
thanks!
thanks!
