You'll need actuator's for how ever many doors you plan on converting, guessing all 4. Usually you can find a kit on ebay fairly cheap that will have actuators and the wiring harnesses required. As far as windows go it can be a bit more tricky. Again you'll need 4 motors, sometimes found in kits, but wiring them isn't too bad. Really the hardest part is mounting everything in the doors. If you don't get switches for the windows in a kit you'll have to get youself some dpdt switches, or double pole double throw, momentary switches. As for lock kits just search em on ebay, you'll find em. Now if your going a more factory route then a boneyard is your best friend, if you can find one with a truck like yours with all the options you want. Hope this gets ya started.[/url]
