Well, there again everyone on the forum and other people I've talked to say they wont bolt up. I dont doubt this, if they would someone would have done it a long time ago.
Now as far as the "junk test" goes, it's gonna happen just to satisfy my own curiousity, and I will let everyone know. As far as mounts go, I dont see any real problems. Made plenty of them in the past.
Now the way I see it, if you get a guy that knows his way around a drafting board & a set of calipers (that would be me) and a guy that knows his way around a machine shop (that would be my buddy), add a good piece of 3/8" plate, should work. I might find out differently, but I really dont think so.
That said, if it works out , I"ll probably make up a couple to keep around for the big day my 2.6 finally craps out. Dont see it happening soon. The main reason for this experiment is that I cant stand that word CANT. Sometimes you cant, but not all that often.
Sooooo....along the lines of swapping, I think If I ever went to the bothernation of a major swap, I'd go with the old tried & true 283 chevy small block. Mild setup should net a extra hundred hp or so, and if you use the loud pedel with a little bit of sense the tranny should hold up just fine. 289'302 fords are a little bit narrower but a tad bit longer. Distribtor is in the front though which is a plus. Just dont like workin on Fords.
Sorry for the long post.
Jim
