I need advice on how to replace a broken camber bracket on a 1995 Isuzu Rodeo 3.2 L V-6 4WD. I attached some pictures to show the damage. I've searched for days to find another one. Note that appears to be welded to the frame, thus it would need to be ground off and a new one welded on. The bracket is a datum for the camber adjustment, so it needs to be true. I discovered that the wheel was toed out about a year ago. I took off the wheel and saw that that the front bolt had backed out. I tightened it and I considered myself fortunate.
Now a year later, I saw the tire off-camber again, but now the bracket is damaged. Unfortunately the firs event mus have damaged the metal and speciifcally the welds.
http://www2.snapfish.com/snapfish/slide ... 157183022/
