'01 V6 3.2L 4wd Rodeo.
Drive slow and hit the brakes normally - they feel fine. Drive fast (50+ mph) and hit the brakes to come to a complete stop and I feel like I've got a hard pulsing against my foot (through the brake pedal). -So, its gotta be brake or wheel related in some form (brakes, rotors, hubs, beerings, etc). I only slightly feel the pulsing in the steering wheel - so I don't think its anything with the rack / suspension (I've driven other vehicles with a blown rack and fairly destroyed suspension before and it was a much more pronounced vibration / forced shifting of the steering wheel).
Does that logic sound right? This is likely a brake / wheel issue?
Problem just started about 2 or 3 weeks ago. It has gradually gotten worse.
Now, I installed Superwinch manual hubs about three months ago and replaced the bearings at the same time. I was certain at the time that I got the bearing nuts installed tight enough. I have double checked the lug nuts - they're tight. When installing the hubs, I broke the tip of a torx bit off in one of the little bolt heads. I also overtightened two other bolts. (these problems were only with one side, the other side was / is fine.) After trying many things, I had to have my mechanic pull these three bolts - this was about 3 weeks ago. I don't know what exactly he did when he did this but it seems that he used a pry bar on the back side of the silver Superwinch hub cap where it meets the black 'backing' metal part because is (the silver piece) is now cracked in that area in a wide C shape that seems to be the length of a pry bar - this is on two different sides of the silver cap. This doesn't extend very far into the silver cap piece though.
The replacement of the three bolts and removal of the Superwinch silver cap piece using (likely) a pry bar is the only change that been done to the front end in a long while. Mechanic replaced the bolts with others I bought from Superwinch and reinstalled the same silver cap piece.
I thought something easy to check would be the ABS system malfunctioning. I pulled the ABS fuse and drove for a while - no change. I don't think ABS is the issue. (The fuse is back in at this point)
No, I don't have the manual hubs locked in the 4wd position and yes, I've tested, the hubs lock and unlock without problem.
The truck is up 3.5inches with a Basic Lift kit from Indy4x.
Any thoughts? What might cause these symptoms?
I'm thinking the cracks in the silver hub cap piece has allowed water in causing the grease to wash out.
Or, my rotors are warped (I haven't hit anything though so I don't know why they'd suddenly be warped).
Or, I've got an issue with the master cylinder (don't know much about brake lines and the master cylinder).
Or, I've got air in the lines.
I'm not sure. I'd appreciate any help or pointers of where to start looking. I don't want to put this into a shop but theres only so much I can do at this point (medical issue causing more trouble). I can certainly jack it up and pull apart the hub and check there and the outer part of the bearing if you think thats best.
Thank yall! Sorry for the long post.
