1) Brakes....Anyone have any recommendations for where to buy calipers? Was changing the pads today and one of the Pin bolts(?) snapped off
So I need a new Rear Right Caliper assembly....
While I'm at it I was thinking of replacing both rear rotors...again recommendation on where to buy and is there an easy way to remove the old rotor?
2) I've also noticed my parking brake needs pulled all the way up to hold vehicle. How do you adjust the parking brake
3) Shocks...How in the hell do you get the top bolt on the rears? Socket will not fit up there. I'm going to have to buy a 19mm open end/box wrench and try using that....is there an easier way?
Vehicle is a 99 Trooper S
