Just bought a '95 Trooper S with manual trans. Seems to be in good shape with under a 100k miles, and only two owners.
I changed the rear diff oil, and wanted to change the front diff, but it has no drain plug. Am I missing it? Maybe it has to be sucked out?
The owner's manual shows two drain plugs for the tranny and transfer case. The one on the transfer case is on the bottom and obvious. The one on transmission is on the left side- not on the bottom, correct? The fill plugs are on the right side and look like a PITA to get to, especially the one on the tranny, correct? The manual says to use 5W-30, but 20w-40 or others can be used if temps are higher than 90 degrees. I'm in New Mexico so temps are starting to heat up. I have some 10W-30 already and am planning on using that unless it's not suitable.
The power steering pump makes some groaning. I would expect it to last longer than 100k miles. Is this a problem area for Isuzus?
Thanks!
Thanks!
