actually with a 95 you'll need new coil springs or coil spring spacers to bring up the rear, the body lift may look like the cheap alternative but will probably cost alot to have installed unless you have the know how
if you crank the t-bars you should consider a ball joint flip or install a spacer to correct your camber angle
good luck either way
PS i went with the BL, less stress on the steering and suspension components in my opinion
