was working fine one moment,turned it off.
a few hours later turned it on-no blower action.
checked fuses-good.
no noise prior to not working,somewhere else to check?
Does it work any setting? Specifically the highest one?
Have you checked the electrical connector for the blower and does it get any power when you turn the switch on?
Try tapping or kicking on the blower motor housing. See if you can get it to start spinning again.
does not work at all.
this is a 97.when i push button for A/C no blue light on button till i turn on blower-A/C button lights up-but no blow.
tried kick it.nuttin honey.
Look at the blower motor housing. It should have a electrical connector plugging into it.
Remove the plug and test it with a multimeter while the switch is on.
I know this sounds weird, but check you oil pressure switch. For some reason if it is not sending the blower system won't get power. At least that is how it is on my '92.
And its mounted in the blower motor housing on the passenger side, under the dash. I had to pull the glove box to get to it on my VX.
If it stops working, you can carefully cut some of the plastic off the top or bottom (there are little shrouds that extend out to cover the electrical connections). I just help mine down with a little pick while I soldered it. I didn't worry about putting the plastic cover piece back on.
Thing to note- these spring loaded tabs are soldered down as a fuse-like device. If it gets too hot (i.e. something else is going wrong), the solder will melt and the tab will spring away, breaking contact. Take note of this because the solder you use will be different than the solder they originally used. Just a heads up.
It appears that you can get these at the flaps (like orielly's) for about $40.
Mines starting to do this. I have a NEW blower resistor in there too (Lost the old one, don't ask..). The "3" setting doesn't work. Sometimes I like to turn the A/C on and set it to "3" for 10 seconds and then turn it on blast to get icy cold air! But.. The past few times I've done that it won't turn on at all. Sometimes switching from vent to floor and back fixes it, odd.
Oh, and fuses are all good like yours.... strange.
Mine didn't work on any of them when the resistor was broken. Resoldered it and it was all working again.
Related Threads
Isuzu SUV Forum
895.9K posts
38.2K members
Since 2003
