161 - 180 of 208 Posts
That´s great! I´m very happy for you keeping the trooper :wink:
Keep the pics coming :p
Discussion Starter · #166 ·
After careful measurements, I discovered about 0.5" rear axle misalignment.
Have to install adjustable rear links to fix this problem. Got materials for links today and will try to complete this project over this week.
Discussion Starter · #172 ·
The front links are Moog Sway Bar links.
Part numbers: K90703, K90702 (left and right)
Available on amazon.com for 24.90 each.
Discussion Starter · #174 ·
Rod ends and tube inserts I got from mckenzies. Tubing from local metal supply shop. Total cost of this project $340.
I wish everything will be OK and I will be able to do trip to Moab this year.
nice trooper where in oc are you? Lets go wheelin some time, I sent you a pm
Discussion Starter · #177 ·
Suspension project is complete!
Installed:
Calmini torsion bars.
Calmini front and rear sway bars with new links.
New rear suspension links.
Calmini front and rear shocks
Calmini rear springs with 1" poly spacers.
Replaced all front upper and rear arms bushings.
Alignment is done.
Very comfortable ride on FW and non pawed roads. Real OFF-ROAD test is not done yet, but coming soon.
EGR/intake SeaFoam cleaning is done.
Trooper did not pass smog test today because I went for test too early after ECU reset. Emission is OK, but functional test was problem. Will pass tomorrow.
