I picked up a pair of Aisin manual locking hubs at the Pick A Part yesterday. Last night I tore them apart, cleaned and greased them, and installed them on my 92 Rodeo this morning.
These are the pics I took during the conversion with a brief description of what I did.
Tools needed:
14mm socket
10mm socket
8mm allen wrench
Snap ring pliers
Small flat head screwdriver or small hooked pick
Torque wrench
Materials needed:
RTV gasket sealer
Medium / Blue Loctite
Anti seize compound
Hi temp bearing grease
Extra 12mm bolt about 2 inches long
Parts Diagrams (click pics for hi res photos):
Auto Hubs
Manual Hubs
Pics:
The Aisin hubs after I cleaned them up. A little rough looking but I think I will wait til it warms up this spring before I strip them and paint them.
Jack up the truck and remove the tire.
Remove the six 14mm bolts from the auto hubs
Remove the hub cap and bearing assembly. They just slide right off without using any tools.
There is a small snap ring / clip holding the drive clutch assembly on. Use the snap ring pliers to remove the clip. There may also be a small shim washer behind the clip that needs to be slid off. Mine was missing on one side.
Now slide the drive clutch assembly and inner cam off the spindle.
All the parts of the Auto Hub removed.
On the end of the spindle you will see two grooves for the snap rings. The yellow arrow points to where the ring for the Auto Hub went. The Red arrow shows where the new ring for the manual hub will go.
Clean and grease the spindle if needed. I just greased my bearings last week so it didn't need it.
Now apply a thin layer of RTV to the edge of the hub.
Now slide on the body assembly and install the 8mm allen head bolts. Apply loctite to the threads first to prevent them from working loose over time. Torque to 44lbs.ft.
The spindle can slide in and out a little so you need to pull it out all the way in order to get the shim and snap ring on. On the end of the spindle is a threaded hole for a 12mm bolt. I screwed in a bolt and just pulled on it with my hand, then slipped on the shim (yellow) and snap ring (blue).
Apply a thin layer of RTV to the body housing followed by the gasket, if you have one, and then slide on the housing assembly. It will only go on one way, well actually two but either way will work. It's a good idea to test fit it before installing the RTV and gasket so ya don't get RTV all over the gears trying to figure out which way it goes on.
Put some anti seize on the 10mm bolts and bolt on the body housing. I have read that the 10mm bolts are suppose to be torqued to 44lbs.ft. but they felt like they were going to snap before they got that tight so I just snugged them up using a 12 inch long socket wrench and will periodically check them to make sure they aren't working loose.
Put the tires back on and you're good to go.
Total time, including taking pics and smoke breaks, less than an hour total to do both sides.
Now go playing in the hills and try them out
Like I've said before, I am new to this mechanicing stuff so if I missed something please feel free to leave me a reply and I will get it added to this post.
Thanks,
Shane
Tools needed:
14mm socket
10mm socket
8mm allen wrench
Snap ring pliers
Torque wrench
Materials needed:
RTV gasket sealer
Anti seize compound
Auto Hubs
Manual Hubs
Pics:
Thanks,
Shane
