I've spent the past few weeks dealing with alternators. I've rebuilt one, bought one, bought pulleys, belts, regulators, brushes, drill bits, more belts, and a 14mm ratcheting wrench. I have learned a lot however.
This all started out because my original (190k mile) alternator was getting tired. It would charge OK at speed, but at idle I'd have to be careful with accessories to keep the voltage above 12.
One of our members wrote an article coving the install of a Delco alternator on his 96 Trooper.
http://www.planetisuzoo.com/articles.htm/99
I had a Delco 12SI from a previous project that didn't look much different than the one that he installed, so I set off to install it. To make a long story short, I'm giving up. The real issue is that the case of the Delco is too large. I can't get a belt on it that can be adjusted. The case touches the engine block and leaves about 1/2" of space for adjustment in the bracket. I could potentially relocate a coolant line for the oil cooler, and get the alternator in closer to the block, but at this point I've wasted too much time and won't do more than take a few more pics of the install before it gets taken out.
I purchased a reman'd alternator for $157.19 from a local parts house, instead of paying $25 for a new pulley (I reamed out the old one to fit the Delco) for my old failing alternator. It is a 75 amp alternator (I'm not sure that my Delco was even capable of the 105 amps that it claimed based on the performance that I saw), and it fits.
The specs from the test sheet are:
Turn on RPM: 1100
Off Lamp Volts: 0.9
On Lamp Volts: 14.4
Amps @ 2000RPM: 37
Amps @ 5000RPM: 75
AC Ripple: 1
Regulator Set Voltage: 14.5
Keep in mind that the idle RPM for this alternator is going to be somewhere around 2000rpm. The crank pulley is somewhere between 2 and 3 times the size of the alternator pulley, and engine idle speed is 850rpm.
For those who are interested, it's model 71-13521 (That's Lester #13521)
Beck Arney sells a replacement as well that's around $240 under part #186-0691.
That number can then be used to buy parts like regulators: http://www.vicic.com.tw/alternators/a806290d.htm
-Tad
Turn on RPM: 1100
Off Lamp Volts: 0.9
On Lamp Volts: 14.4
Amps @ 2000RPM: 37
Amps @ 5000RPM: 75
AC Ripple: 1
-Tad
