1 - 3 of 3 Posts
· Registered
I cannot believe I have to ask this, but how do I replace the rear brake light bulb? My truck came with cheap plastic guards that I believe are OEM, are they covering up the screws on the outside of the lense? They are held on by an adhesive I would need to remove. However on the inside of the lense area towards the tailgate, there is a black plastic cover that I cannot figure how to remove. Is that the access to the bulbs? Seems awful tight on the hinge side. Oddly my Isuzu manual shows nothing on replacing bulbs.
· Registered
Dunno if you got PM'd on this or not, but there are 3 screws holding the lense in. two are inside the vents on the sides, and one is below the black trim at the bottom of the lense. if you can't get it, PM me and i'll get you a pic.
here's a pic:
· Registered
Just get two flashlights, tape clear red cellophane on the lightbulb lens, and duct tape them to the rear facing backwards turned on. Everyone will think you're always braking, but this may work to your advantage.
Hope this helps...... :p
1 - 3 of 3 Posts
