1 - 4 of 4 Posts
Need help
What is torque specs on rear differential bolt ?
And EGR ? I have a manual but it doesn't show.
Thanks
When there is a bolt I want to torque and the service manual doesn't give a torque I use a standard torque chart such as this one from Fastenal https://www.fastenal.com/content/merch_ ... 0Guide.pdf just find your bolt dimensions and grade . I would think the items you mentioned might not have a spec different than standard torque specs.
Keep in mind most standard torque specs are based on the fastener going into steel or iron , if the fastener is threading into aluminium the torque spec will be decreased. so look for a spec sheet that includes that.
Richard10 said:
Need help
Thanks
My Manual Says 30 Foot Lb DOR DIFF bolt, EHR , I couldnt find
1 - 4 of 4 Posts
