I have been following the instruction that a search has brought up.
I have a couple questions though:
When moving the pintel around to free it up are you supposed to stick
a star (torx) screwdriver bit in there and go left to right? Or just make
sure it goes up and down easy. Then use a bit of force to make sure
it goes down all the way? While spaying/soaking the hell out of it.
I used three types of cleaners from carb to electrical parts cleaner.
How much black stuff should still be in there. It just would not come
out.
On the intake right under the EGR there is a "cap" that has a hex bit
opening. Should I have opened this and stuck more cleaner in there
to? I seems to be connected to the sucking part in a "Y" fasion to the
EGR.
Is it OK to put cleaner in the exhaust (blowing) part? I stuck a ton
down there and it all seemed to come out the exhaust.
After all this I shook the EGR and was able to hear the pintel move.
Good?
All in all it seemed to be very clean before I started anything even
after 40K.
For about a minute after finally getting the truck started there was a
sulpher smell is this normal?
out.
EGR.
Good?
after 40K.
