Okay, another update:
My oil leak was from a bolt that I left out of the oil pump. It was one of the bolts that holds on the wand that goes down to the oil filter. I put a new bolt on, and that fixed my leak.
The shop said all of my AC parts were leaky or going bad, so I am replacing or have replaced the condenser, evaporator, compressor, expansion valve, and am thinking about cleaning the blower fan, because it's not blowing quite as strong as I'd like.
All of my speakers work, but I think I have some shorts at the actual stereo plug. I may just buy a new head unit and have a shop install it.
I installed some MSD-8224 coil packs and increased my spark gaps to .059 in, as inspired by Brent Tri on Isuzu Trader. I highly suggest this upgrade, as everything seems to have a little more umph.
I have oil for my transfer case and diffs, and stock skid plates to install soon. Looking forward to my first off road trek in the near future.
I also acquired a leather steering wheel. I may try to make a heated steering wheel. I am also contemplating adding stereo control buttons to the back of it.
Here's the list update, I've actually made quite a bit of progress.
- Things that still need work
--- It's leaking oil
--- I have a weird idle pattern. Need to check the wiring on the TPS, IACV, and MAP sensors. Going to have a professional check for vacuum leaks
--- I buggered up the ac controls for the vent position. Also the light doesn't come on for the AC when the button is pushed in.
--- One of the belts needs a little tightening
--- One of the doors still needs the interior handle to be attached
--- Heated seat doesn't work and the light doesn't come on for the switch on the driver's side
--- Safety belt ends don't match up and need to be changed on the rear seats.
- Other things that I have to do.
Change out the break in oil.
--- Change the fluids on the
transmission, transfer case, and differentials
--- Install OME springs and shocks
--- Install new front sway bar and bushings
--- Change the U joints (I have driveline shunt)
--- Have the AC coolant charge checked
--- Install new CVs (my outer boots are torn and no longer contain bearings)
--- Install new rotors and brake pads
--- Swap in my Aisin Manual hubs
--- Install the Yakima roof racks
--- Have the stereo seated properly (upgrade the speakers too?)
--- Grease the wheel bearings
-Extended to do things
--- Rear cupholder
--- Rear gate handle
--- Trunk handle bars
--- Map lights
--- Compass/temperature reader
--- New bumpstops
--- Fabricate rear lock/unlock button in trunk area
--- Custom Y pipe and new muffler
--- Snorkel
--- Bumper guard / new bumpers????
--- Upgrade to HD tie rods
