Well, seems I probbly wont attempt to do this alone in my house garage lol. I just wasnt sure if it was as simple as a oil pan drop, few bolts that hold pump on and put pan back on kinda thing.vzfox said:I did recently change the oil, about a week ago. I used Castrol High Mileage 10W/30 with half a quart of Lucas Oil Stabalizer with a new oil filter. It didnt do much anything for my pressure issue, it showed about the same as before the oil change.
It doesnt smoke or leak any oil either and idles and drives just fine.
But do you think a simple engine cleaner would clean and clear the valve train body to pump better oil to that area?dman4486 said:the pressure starts out high on mine and drops low when it warms up too... but when mine drops the motor has already started ticking. my thought (which I am working on proving) is that the valvetrain is what is causing this on mine.
I did a little bit of reading up on the Rotella T 15W 40 oil...it seems it may be my best way increase my oil pressure at operating temps without spending a couple grand for a new motor. I live in Dallas TX, so the tempature here isnt going to get cold enough to cause the oil to get "sludgy". I am currently running Castrol High Mileage 10W 30 with half a quart of Lucas oil stabalizer.dman4486 said:no... don't think it will make any difference. I tried the flush in mine... Best thing I ever did to mine was running Rotella oil. Cleaned out the varnish quite nicely and handles the tick and oil pressure until ready to be changed.
So you dont contribute any of the clean engine to the engine flush you did, only the rotella oil? I will probably do an oil change to the rotella 15/40 in a couple weeks, unless anyone else posts a better stratagy.dman4486 said:also... after putting the first dose of Rotella in.. the oil turned black in about 100 miles. had to change it. Then black again around 500 miles. Now I get about 2000 before it goes black. but the inside of my motor (since I had it apart this past week) looks really clean compared to how it was previously.
But do you have an oil pressure issue...like stated earlier in this post, mine goes from 40psi or so at cold start up to 5psi or so at operating tempature. When at idle, in drive at stop light....my oil light will flicker (i do have a factory gauge on it also)vanduker said:If you do the 15w you can buy it in 2.5 gallon jugs at Sams and the 5w you can get at Wal Mart. I'm in OKC so about the same climate and use the 5w but think at least for non winter you can get by with 15w.
