vzfox said:
The a/c will run constantly rather the a/c button is pushed in or out.
Suggestions on what to check for and how to test them plz
1995 Isuzu Rodeo LS V6 4WD
Update, this is gonna sound stupid, and i think its way ignorant but check this.....I just bought this suv from an individual about a week ago. He mis represented his sale saying the a/c works great and all windows work. I made the purchase on his word (Im a trusting guy as a fault). When I got it home, I found that not only were the shocks and brakes shot smooth to hell but the oil looked like mud. The more I looked into this suv, the more disappointed I was. So far, I have put new shocks on, new brakes and changed the oil and put some Lucas oil additive in plus a small bit of Lucas transmission lube in the tranny. The suv looks really good and hopefully now it will run better.
Now, back to the point at hand.....on the a/c, this is what I found. The clutch plate had been welded to the compressor wheel in three spots. Yes, you heard right WELDED!! Why, one can only imagine. I spent alot of my morning today with a dremel cutting the welds loose. After doing so, I replaced the fuse in the under hood relay box and WAALAA, a/c works just as it should going on and off with the push of a button. Now for some unknown to mankind reason, the ******** I bought this suv from welded this....there has to be a reason to that insanity. :roll: It does make an horrific noise now when the a/c is turned off, but as I watch the compressor turn without the clutch welded to it, it does still try to spin somewhat catching on the cut pieces of weld. Im thinking if I drive it a while with the a/c off the weld pieces will grind themselves down and stop skreating to high hell. I also found the other side of the green wire connection while I was under the truck cutting welds and reconnected them. Maybe that wire kept a/c from working properly and they decided "hey, lets just weld the fkr into place" ughhhhh. I will find out more as I drive around if there was actually a reason for the welds.
As for the power windows (another thread I have here)....Previous owner also said they all worked. When making the purchase, they didnt work. He looked amazed and said "thats weird, they all did work just yesterday".....BS. The child lock on the main window switch was smooth broken inside the assembly, preventing ground from being made to operate any of the windows. And from what I could tell, that child lock didnt just break, it had been that way for some time. Anyways, got another main switch ordered and should be here within a few more days.
To top things off, listen at this (I know im rambling now but still)....he sold this suv because his 16 year old daughter was about to start driving and she wanted a smaller vehicle. What person in there right frkn mind would give such a delapated, un cared for vehicle to their own daughter to go kill themselves in...WTF!! :evil: but anyways, its my prob now and hopefully the kinks are all getting worked out little by little. If you see more threads posted here by me, plz do help me as much as you can. Im running low on money and patience and need a safe reliable suv :wink:
