carlosian said:
thanks for the advice blue. so in a nutshell, i have to remove the odometer, look that back of it for the places where the lights go into and replace the lights? right?
thanks
You have the curved dash, right?
If so, here's what you do.
- Remove the 7 screws holding the black dash besel on. There are two above the instrument cluste, one above the radio, and two on each sideof the steering column.
- Pull out the ash-tray and remove the black trim around it (it will simply pull off as there are no screws securing it).
- The bezel can now be pulled off.
- Once you get it loose, you will have to disconnect the dash switches.
- Now that you have access to the intrument cluster there are 4 screws securing it. Remove these screws and you can get to the back of the cluster to replace the bulbs.
You can either buy clear bulbs and swap the green rubber sleeves to the new bulbs or buy colored ones. As Blue pointed out, you might as well replace all four while you have the dash apart.
