1 - 6 of 6 Posts
Hey Ppl, I jus bought a 1994 trooper and I want to lift it.... But I cant find a suspension kit anywhere??? Is it available or am I stuck with a body kit as my only option.... Anyone know?????
start here:
https://www.independent4x.com
and you can search for all that info here and if you read a few days worth of drivetrain mods you"ll find your answers
:D try this on for size.3 inch old man emu suspension lift.$674.99Extended lenght OME Nitro shocks (our exclusive), Med. Heavy rate OME rear Coils, 1" Spacers, our Ball Joint/ Bumpstop kit, & Rear Brake-T extension. AWESOME RIDE QUALITY in a Budget 3" lift Package! 1992-2004 Trooper or 1999-2001
https://www.independent4x.com/merchantm ... cts_id=427
1 inch body lift for a very easy and cost effective.
here you go, great way to get that extra little boost to fit the next tire size. 85-2002 trooper 1" body lift kit. includes Pucks and replacemant bolts for the front + instruction sheet. front metric bolts are used for the rear to complete the lift
https://www.independent4x.com/merchantm ... cts_id=152
you can run 35 inch tireswith 3 inch suspension and 1 inch body lift.below is a pic of my trooper 8) recon
here is a pic of my 95 trooper with 3 inch body and 3 inch suspension lift with 35 inch mud tires 8) recon
Recon, do you have any rubbing issues out on the trails
I'd like to run 35x12.5 on 15" rims
1 - 6 of 6 Posts
