1 - 3 of 3 Posts
I have a 94 3.2l rodeo that fires but will not start. New timing belt 2 years ago. All vsv vacuum lines replaced. New ignition control module six months ago. I checked faults with jumper, flashed 42. I pulled plug wires individually and manually checked spark, weak to nonexistant. I disconnected the battery and the code cleared. Still no start. All relays and fuses have been checked. Anyone with any ideas? Any help appreciated.
fuel pump? fuel filter? does it crank?? you mentioned theres weak spark, is it on all 6 plugs??
Thanks for the reply. I did not mention that I had fuel pressure and grounds are good. As for spark,i pulled plug wires from the coils one at the time and two had intermittent weak arcs and the rest none. I have since checked voltage to the ignition control module, checked good. Ground also ohmed out. It would seem that I have another bad ignition control module. I will replace it tomorrow and let you know what happens. I really appreciate the input.
1 - 3 of 3 Posts
