1 - 4 of 4 Posts
wanted to know if anyone had this problem before. my truck when you start it up and drive is normal you press on the brake not enough to active the brakes but just to turn on the light you hear it clicking like its coming from the glove box area and it is speed based click, but when you get up to freeway speed the brake and rear abs light comes on and the clicking stops. it started about a few days ago so i changed both front and rear pads had the rotors turned, and it is still there any one had the same problem or know about it or a fix let me know :D
bump for week crew
bumping again hope someone knows
I'm no expert on ABS (hate it) but it seems you have a wheel speed sensor problem. When the ABS light comes on, it disables the ABS system so the problem SEEMS to go away but only because the system is ignoring input from the sensors.
1 - 4 of 4 Posts
