1 - 7 of 7 Posts
OK MY BUDDIES TROOPERWILL JUST DIES WHEN U PULL UP TO STOP DOSENT SPIT OR SPUTTER JUST LIKE U KILLED SWITCK IT HAS 3.4 SOHC ANY HELP WOULD BE NICE
All 92 troopers came with 3.2L Isuzu v6. Dohc or sohc. is it am Isuzu or GM motor? If Gm its a 1st gen 91, the below advice is valid for any idling stall though.
You may have a vac leak. My 92 had a split PCV Valve, ran great sometimes & just stalled at every light other times. Grime plugged the crack & it ran ok, sucked grime through & then air gets in bypassing the maf, int system sucks via pcv hose more & more unmetered air causing a nasty sensor mismatch between maf & tps & o2 readings... Thus a stall occurs.
Get a large can of o2 sensor safe carb cleaner & clean off all vac lines/seams/joints with engine warm & idling, I bet you find a spot that sucks in cleaner & chokes the motor out. Fix the leaking item (prickly by replacing) & it should run better.
~psguardian
1 - 7 of 7 Posts
