· Registered
I am looking for a line for my clutch on my 91 trooper 2.8 v6, 5 sp 4x4 tbi. It goes to the slave cylinder and has a banjo connector on one end and a nut on the other (connects to a box on the drivers wheel well in pic... not the master cylinder).
The line I need is about 61 inches long and has a rubber section in the middle of it... as it goes down the firewall to the slave clutch cylinder. I can't seem to find the line anywhere.
(note: the line in the pic is in several pieces)
Hand tool Wood Metalworking hand tool Bicycle part Tool
Automotive tire Rim Motor vehicle Gas Automotive wheel system
Automotive tire Serveware Auto part Automotive wheel system Rim
Scaled reptile Snake Reptile Wood Asphalt
I live off grid a couple miles from a small town, so my truck is critical.
Suggestions appreciated.
Mike
· Registered
(note: the line in the pic is in several pieces) View attachment 120150 View attachment 120151 View attachment 120152
Mike
I have new and used clutch hoses available
· Registered
1989 Trooper R/S
Also this previous link may be of some help
· Registered
I can give you the details on how to order a coated stainless steel clutch hose if you’re interested (like the ones Eric at classic city overland used to sell). I installed it to go direct from the master to the slave cylinder and eliminated the clutch damper. Much easier to install and bleed. Mine was for the 2.6 so I can’t say for sure if the banjo fitting and cable length would be the same but that shouldn’t be too hard to figure out.
mike
· Registered
mike
Yes please.... especially anything that has the banjo.
· Registered
I finally got the new clutch line installed. Thanks to Benjamin at Ameriflex in Tulsa for the custom work.
Now I am ready to start replacing the Alternator Bracket... then back on the road
