You can build up a 3.1 to be a pretty strong runner. The increase of torque due to the longer stroke is the biggest benefit.
Of course, you could also put a 3.1 crank and pistons into your 2.8 block and accomplish the same thing. Use pistons out of a Rodeo/P'up 3.1, or a Camaro 3.1.
The bores are essentially the same, and the heads on all TBI RWD 2.8's, 3.1's, and 3.4's are the same '884' casting. Rods are the same across all three motor displacements, too.
ARI sells a kit specifically for this purpose, with crank, rods, pistons, bearings. Not too bad of a deal, either. But you could probably scrounge and find a good 3.1 crank and the correct pistons, at a junkyard or on eBay.
You can also get a rebuilt Rodeo 3.1 motor with 7 year, 70,000 mile warranty from these folks for $1243 + $150 Core + Ship:
http://www.rebuilt-motors.com/cgi-bin/w ... 3169268.b9
I know a fellow who put one of these in his Trooper. He was concerned with reliability because he was planning on taking a trip into Mex. He wrote me back saying the rig ran like a champ, even with all the poor quality fuel, and never missed a beat. He was pleased with the power too. If you do the same hop-up tricks you can do to any of these, you should be able to wring around 150 HP out of a 3.1. More torque and 25 more HP will make a very noticable difference in the way your rig drives.
Of course, nothing like the 3.4 for brute torque and HP. You can make a template for the starter holes, it's not so bad if you're careful about it. I did mine freehand with a portable drill motor, and have had no problems. It can be done!
Re: the tuning issues, either use the 2.8 TBI with 4.3 injectors installed, or bore out the intake and use a GM 4.3 TBI or Holley Big-Bore.
The 4.3 injectors installed in the 2.8 TBI do solve the 3.4's lean-surge-when-cold problem, of course you'll get more power out of the 4.3 or Holley TBI's.
If anyone would like the collection of swap info I've accumulated over the years, just send me a P.M. with your e-mail address and I'll send you the stuff.
Cheers.............ed
