Thanks for the input guys. I also am doubtful that I can extract the bolt, but the engine is shot if I can't anyway. It was running solid but I wanted to do some maintenance and opened another can of worms when the bolt broke. Believe me I tried the bump trick several times and it would not break loose. I have a feeling it has some locktite on it. The block has 195K on it so it has had a long life. So I am planning on pulling the engine as I don't think I could do a proper stab at the easy out while in the truck. If it works, great, if it doesn't work then the engine is out and then put the other engine in. One thing I want to do before I pull it is to do a compression test. I have never done that on this little truck. I know the head is good. It has only about 25K on it and has the 260 delta cam. The head is an AMC. And I have done the valve adjustments at least 2 times since I put it on.
The potential replacement engine is supposed to have about 150K on it and they had recently done a valve job on it and had replaced the clutch. Then it got torched. Completely gutted the cab but did not melt the heater hoses.
In the back of my mind I keep thinking to just get the Spacer back running and then take the short block and bore it and drop the AMC head on with the Jerry cam and I think I would have a great running Spacecab.
OR, Bart is adverting his rebuilt engine on Ebay for $1550 OBO. I have seen the engine in person, it is a beautiful thing to see. He only lives about 300 miles from me. I bought a bunch of his stuff already.
1st step is to pull the screwed up engine......
