1 - 2 of 2 Posts
When i remove the valve cover on the 2.6 straight 4 will I need to replace the gasket, or is it the rubber reusable type?
Any pointers on adjusting valves?
Thanks,
Mike H.
Mine is rubber, but I'd have a spare just in case. If you bought the truck used, you don't know whether the previous owner put some gunk on it.
There is an article on adjusting the valves at http://www.planetisuzoo.com/articles.htm?id=64
The valve cover is held down by just 3 screws. However, you will have to remove some "stuff" to get it out of the way. Get yourself some sticky shipping labels and label everything, vacuum lines and wires, so that you know where everything goes back.
You will also want to remove the plugs so you can turn the motor easier.
1 - 2 of 2 Posts
