1 - 20 of 97 Posts
...part 2?
Hello all. It's been a while, but I'm back with the original Trooper. It made a few cameos in my original build thread of the off road truck I built 11 years ago and chronicled on this site. My parents bought this one brand new in 1988, and it has never left the family. It criss crossed the country many times, often pulling a Uhaul, as we moved from place to place. It's been a very reliable truck, and my parents took great care of it. The interior, although slightly worn, is spotless. It has a little bit of rust around the windshield due to shoddy windshield replacements over the years, and a small amount in the rockers. I believe there is a little bit hiding in the rear doors as well that has been covered up by body filler from past repairs.
Last year, the clutch stopped working, so I towed the truck to my house and figured I'd change the hydraulics and send it back to the parents.
Crawling underneath revealed oil everywhere. It was leaking so much engine oil, it was impossible to tell where it was coming from. I did the only reasonable thing I could think of. I yanked the motor.
While the engine was out, we scrubbed the engine bay for a few hours and cleaned up the frame rails and front end as well as we could.
Then we started teardown of the engine to see what was leaking, and assess the overall condition. The rotating assembly looked great, so we rehung everything and cleaned up the block for paint. All the bolt on parts were media blasted and painted.
This right here is my little helper. She's a little superstar and learning quickly about cars. Just about any time I was out working on the ol Troop, she was right there with me.
Finished product.
With the engine back in and running great, clutch hydraulics replaced and working properly, and Troop running around under its own power again, it was time to address the rust. With rust repair comes paint, so I figured to spray the whole truck.
Then it came time to pull the rear bumper. And the project went WAY off the rails. One bolt snapped and the other 3 just spun, meaning the captured nuts weren't secure anymore. That usually means...rust.
I'm familiar with rust. My other Trooper had rust. It had rust to the point of being a unibody truck with some rust hanging down where frame rails used to be. That one got a complete frame swap. Maybe this needed some investigating.
So I cut the bolts off and cut some holes in the crossmember to see what I could see. It wasn't good. The crossmember was full of rust flakes.
You know what's next. It's time to yank the body. This went way farther than I ever intended, but I've always been a fan of overdoing something and not having to mess with it again.
The tub looks great, but of course the captured nuts on the rear body mounts spun and I had to cut the bolts off. I'm getting good at cutting body bolts.
Off she goes.
Upon inspection, the crossmember is really the worst piece. The frame is solid still. It has some rust flakes in it, but no cancer and no soft spots. If I found a completely rust free frame, I would probably swap it; but for now, I'm going to strip it down.
After a week or two of thrashing on it whenever I could, I stripped the frame down and got it to a good state to blast.
I think these were bump stops at some point in time. They're long gone.
That's where it sits today. I'd love to dedicate all my time to it like the old days, but I'm working 12 hour nights due to the Covid stuff. My one or two days off are usually spent catching up on house and family stuff. I'll update as I go along.
That is looking great, I wish my kids would do something like that, but they just think I am nuts. Keep up the fantastic work!
Awesome. So glad there is still a troop in your life! Looking forward to watching this progress.
Diggin' it. Just finished my first and hopefully last foray into body mount nuts, bolts, and bushings. That trooper is going to come out the other end as good as it was fresh off the factory floor. Good luck!
So impressed with your work! Especially the speed in which you are doing this!
I also think your little assistant probably has more mechanical skill than I do. :oops:
It's been a few weeks, here is where we stand now. Frame is back from galvanizer, washed with degreaser.
To get paint to stick to zinc, you have to etch it. I used vinegar to wash it down, then a thorough rinse and into the garage for drying.
And finally, a good spray of epoxy. I used Summit Chassis Shield, I haven't used it before but I like the way it sprays out. It's supposed to be satin, but it came out glossy. 2 heavy coats later, she's ready to dress up.
1989 Trooper R/S
Awesome, what a complete build. Don't remember following along before, but will now. Gotta see the end result.
Beauty work!
Your first build was literally one of my favorites. I'm subscribing to this one! Looking great so far!
Lower control arms have been blasted, but they had some flaky rust inside. They got a bath in some Ospho.
I used to be able to take parts to work and use their industrial blast cabinet. Due to changing jobs and not working nights anymore, I bought my own to use at home. Highly recommend. My compressor is slightly undersized for the air consumption of the cabinet, but as long as I go slowly it works great.
Pics of progress over past few months. I spend most of my spare time wrenching on this thing. It has fought me every step of the way, but I think I've turned a corner.
1 - 20 of 97 Posts
