shooter said:
So it sounds like either a bad voltage regulator or that "diode" which is used to prevent the battery from discharging back to the alternator. As you probably know, you never (if possible) want the alternator to charge a very low battery due to it will soon fry the alternator. Regarding electric fuel pumps (in tank), they are designed to operate on millivolts (they initially receive 12v) to minimize explosion. Glad to see the schematics might prove helpful.
I did one more test this morning.
NONE of my own circuits are causing a drain.
So, everything else disconnected... I mean everything. ECU, Radio, everything.
With the round plug removed from the alt, but the fusible links connected, (That square black connector at the battery positive terminal.)... Weeee tiny draw. (That is the gremlin I was chasing yesterday.)
With the round plug removed from the alt, and the fusible links disconnected... Zero draw.
With the round plug plugged in, and the fusible links connected... Draws everything the battery has.
With the round plug plugged in, but the fusible links disconnected... Zero draw.
Conclusion:
Unless I am mistaken,
The alt is not charging the battery up, while the truck is running. (While running, the battery drains.)
And the alt by itself, is drawing the battery down, while the truck is not running.
Yesterday, I walked away frustrated. Left
everything connected to the battery.
Luckily, I had unplugged the round connector on the alt, and hadn't plugged it back in.
This morning... The battery tests out at exactly the same level it was, when I closed the hood yesterday evening.
Again, further proof that it is the alternator that is at fault.
Thanks again, for the data.
In my testing I have noticed that when the truck is turned off... The ecu draws more from the battery, than the radio does.
Pretty good radio, I guess.
Next up is taking the old alt out, to see if the new one can be put in it's place.
If not. I have already discovered that I can mount the new one, where the smog pump was. (Just need a piece of pipe as a spacer.) Bonus to this is it gets the alt up toward the top of the engine.
I just don't know if the belt will work with the alt put up there.
One trick I have up my sleeve... If the new alt will not fit in the old position, and the belt won't work in the new one... I still have the belt tensioner that I took off when I removed the AC. I may be able to work something with that, to get a belt to work, with the alt in the higher position.
