1 - 3 of 3 Posts
Ok, the Trooper was running great until I went on a trip of about 150 miles. Got back home and it has been running rough and seems like it has a rich fuel mixture. Improves under acceleration, starts bucking when I let off the throttle and has a miss at idle. Seems like I have had trouble with the Trooper every time that the gas tank gets below about 1/2 tank. Could I be getting trash past the fuel filter and into the carb?
Help! Thanks everyone.
Here's some more information on the Troop. I went out and pulled the plugs tonight. The #1 plug looked great, the rest were black - not soaked with oil but dark black like carbon or soot. I put everything back together and started it up. I could hear a hissing sound near the black canister on the passenger side of the engine (I'm not sure what this is for). On the bottom of the canister is a large nipple - I put my finger over it and I could feel a vacuum - nothing is connected to it.
Is anything supposed to be connected to the bottom of the canister? Any other ideas?
Did some more research and realized that this is the charcoal canister. Like I said in the previous post, there is a nipple on the bottom pulling vacuum with no hose attached to it. Is this normal? I can't find any loose vacuum lines.
1 - 3 of 3 Posts
