I have a hose coming up from the IAC valve but is not connected to the throttle body. See second pic where you will see the hose with the bolt at the of it.
The throttle body has an adjuster screw on top.
I have a 1988 trooper 2.6 and i dont think the throttle body that is on there is correct. Which year is mine from?
Can i just swap the correct throttle body or do i need to replace the upper intake manifold as well?
