I've got a line on a '93 5speed tranny setup. First of all, will everything needed to do the swap work on my '96 if coming from a '93? Second, the tranny has a whine likely from the input shaft bearring and has had it for 150k miles, should I just replace the bearring or should I have it rebuilt?
Thanks guys!
** Bump and Title Edit for Possible Replies **
sorry, not sure about the answer to your question but im interested in your swap as i plan on doing the same to mine. i would call a reputable tranny shop (or a few) and ask them. is it an mua5?
Thanks guys!
THE 93 TRANS WILL BOLT IN FINE BUT YOU WILL NOT HAVE A WAY TO SHIFT THE FRT AXLE IN AND OUT SINCE YOUR TRANNY HAS THE SHIFT ON THE FLY SETUP ON THE TRANS FER CASE ,YOU COULD DISASEMBLE BOTH T/CASES AND USE THE 96 PARTS ON THE 93 MAKING THE 93 A SHOTF SYSTEM OR USE THE 93 AS IS AND USE MANUAL HUBS AND THEN LOCK THE AXLE ACTUATOR IN ALL THE TIME ,WHICH IS MUCH EASIER THAN SWITCHING AROUND THE T/CASES
JLEMOND said:
Thanks guys!
Gotchya, will all of the other parts needed for the swap be able to be taken off of the '93? What all parts will be needed...?
I will actually be using the axle off of my other '93 and have manual hubs already. Should I just stick with my '96's transfer case or snag the one off of the '93?
Mediamonkey11 said:
JLEMOND said:
Thanks guys!
IF YOU HAVE THE 93 FRT AXLE YOU COULD USE IT , BUT FOR THE AMOUNT OF WORK, JUST REMOVE THE FRT COVER ON THE FRT AXLE ACTUATOR ON THE 96 LOCK THE SLEEVE IN PLACE FOR 4WD USE AND USE IT THAT WAY. NOT HARD TO DO AND TAKE ABOUT 45 MIN ,TO DO WITH OUT ALL THE WORK INVOLVED SWAPPING THE ENTIRE FRT END , THE 93 FRT AXLE WILL BOLT RIGHT IN
Yah, the '93 axle has the locker and diff drop in it which is why I wanna swap it into the '96. Should I just plug the vacuum hose going to the actuator?
JLEMOND said:
YES JUST PLUG IT UP
Wurd. Thanks, Jerry!
JLEMOND said:
Mediamonkey11 said:
JLEMOND said:
Thanks guys!
Whats the best way to lock the actuator?
Press the 4wd button and keep it on all the time.
