Please read fully before contacting me
2 Isuzu Troopers, $1900 for both
Or possible trades
Liam - Call/text anytime - (828)-434-5961
#1 2001 Trooper 158,000 3.5 DOHC V6 oil psi 70cold/40hot at idle, 5 speed Aisin AR5 manual transmission, Isuzu Torque-On-Demand 4x4
Everything works on car, wreck was 5/10/22
#2 1999 Trooper 199,000 3.5 DOHC V6
Cylinders 1-4 have 160-170 psi, 5 and 6 have 50-60 psi, both on driver rear of engine, believed bad head gasket or burnt valves
Engine runs but poorly, no transmission, no fuel tank, has 4x4, transfer case, driveshafts, and other parts are in trunk
Got #1 with bad auto transmission, after many failures with the auto, I got #2 from SC to do manual swap, as the engine in #2 had issues
#1 has bent frame, #2 is in great shape, no rust from SC
They both have many good parts, you was could put both together into 1 good Trooper, but I don’t have time or ability/tools Can hear #1 run,move,and test 4x4, #2 has no flywheel/ring gear (its in #1) so cannot start
I have many more pictures
Contact for more details, delivery available
Or possible trades
