Ok
So I've got an 89 amigo, 5 speed, with a 4ze1
When its cold, the truck will not idle without throttle, and at times you can smell unburnt gas as if its running rich. Once it reaches operating temperature, it runs decent, but it will occasionally surge while accelerating, it idles at about 500 rpmwhich is lower than what it used too, this all started about 2 weeks ago out wheeling, I have replaced the fuel pump, fuel filter, and fuel lines running from the pump and fuel filter.
The valves were last set probably about 4000 miles ago last summer when I replaced two new ones.
The reason for the fuel filter and fuel pump is I checked the fuel pressure when this all started, it was fine at idle, about 40, but under throttle it decreased to about 35. I haven't checked it since the new pump and filter, but I'm assuming its the same since its got the same symptoms, on the test drive today I was running 55 mph and everything felt fine, but the check engine light came on for about 10 seconds and then went out.
would a bad o2 sensor cause this?
Fuel Pressure regulator?
Does anybody have any other ideas?
