That looks like the intake from a G200 1.9L, from an 85 or 84 Trooper or maybe a PuP. It could also be from a G180 from 83 back to Chevy LUVs in 76. I think I see a large port for a mixture control valve though which wasn't on any of the LUVs that I've owned. At any rate, it is not from a 2.3L 86 Trooper. I bet if you put a 2.6L intake gasket up to that you'll find the openings on that manifold are a fair bit smaller.bmw2002 said:I am in the middle of converting my 88 trooper to a weber. I purchased this isuzu carburated intake from a used parts guy. It looks different from yours and I am not sure what it is off of. He said it was a 2.3 trooper. The bolt pattern is the same. Any Ideas? I have already plugged the oil hole where the fuel pump indention is so that wont be an issue.
I am trying to find a 2.3 intake. If you know of any let me know. Also has anyone tried an offenhauser intake manifold on a 2.3 or 2.6?
There's actually 2 plates involved with the fuel pump. The actual pump replacement plate on the exterior manifold and the brass shim stock on the opposite side. Any vacuum fittings remaining were capped with vacuum line fitting caps. The assorted vinyl colored ones last much longer than the black rubber ones. Silicone ones are the best. I too caught a little flack. As I like to say, "screw 'em". March on with your project.cjreed10 said:Shooter, the write up says that the block-off plate for the mechanical fuel pump should be between the intake manifold and the head; however, the picture shows the plate mounted on the outside face of the intake manifold. Can you mount the plate on the outside face, use a little RTV and install nuts on the studs? Which is it my friend?
Also, what did you do to plug the vapor lines running out of the driver's side of the head?
Love the fact you eliminated the EGR valve. I started a post last week wanting to do exactly what you have done and I got my hand slapped by a few guys on the forum... Any pros/cons to the decision?
Yeah, what is it with those black rubber caps anymore???shooter said:The assorted vinyl colored ones last much longer than the black rubber ones. Silicone ones are the best.
Yeah Jeff the black rubber ones are junk. Might be the vapors, heat, both. Have had no issues with the vinyl ones. Not sure how large they go in silicone. Bought a large assortment of them when I was doing the conversion. Evidently my shop ate them.Selador said:Yeah, what is it with those black rubber caps anymore???shooter said:The assorted vinyl colored ones last much longer than the black rubber ones. Silicone ones are the best.
Cheap china rubber?
I didn't think I should trust the vinyl ones, but after my experience with the rubber ones, and your recommendation here, I am going to re-think that.
I wonder if I can get the silicone ones in larger sizes, and I wonder if they would last as caps on a steel coolant line?
A 1/2" pipe plug with lots of Teflon tape can be make to work, but it really doesn't "fit".electricpuppyboy said:Bump for a great tutorial.
I just read through this all again because I will be tackling this swap soon.
A few questions:
Did you make all the block off plates, or did you purchase them?
If I keep the EGR system, can the 2.6 valve and pipe be used, or do I need the 2.3 stuff?
If I delete the EGR system, what do I use to block the hole in the header?
A 22m x 1.25 bolt will do the job.electricpuppyboy said:If I delete the EGR system, what do I use to block the hole in the header?
oldestisuzuist said:EGR bung is M22x1.5
Uh oh...Which one is it?Selahdoor said:A 22m x 1.25 bolt will do the job.
I could be wrong about the 1.25. It could be 1.5. I don't have anything like a package to refer to. And it would be impossible for me to get in there and see what it says, now. LOLelectricpuppyboy said:Uh oh...Which one is it?
After oldestisuzuist replied, a search turned this up:
http://www.napaonline.com/Catalog/Catal ... 0373909230
I was not as lucky searching for M22-1.25.
made the plateselectricpuppyboy said:Bump for a great tutorial.
A few questions:
AgreedSelahdoor said:...it would be impossible for me to get in there and see what it says, now. LOL
I suppose I would want to make this one shorter too (as to not block the exhaust).Selahdoor said:The one I bought only had about half as long of a threaded portion as the one in your link.
I just dug my stock exhaust manifold out of the weeds & checked the EGR bung with a M22x1.5 tap-it fits.electricpuppyboy said:oldestisuzuist said:EGR bung is M22x1.5Uh oh...Which one is it?Selahdoor said:A 22m x 1.25 bolt will do the job.
Sweet! Thanks!oldestisuzuist said:I just dug my stock exhaust manifold out of the weeds & checked the EGR bung with a M22x1.5 tap-it fits.
