Oil consumption shouldn't be any different, the PCV valve is connected to the port on the carb?
The carb itself does not have a dedicated port for the pcv. I originally had the pcv line run up through a hole in the bottom of the air cleaner housing (per Weber instructions and illustration). During that time, a small yet steady volume of visible emissions would escape through the small breather filter. I then used a reducer and smaller line and ran the pcv to one of the small vacuum ports on the intake manifold beneath of and offset from the carburetor. No more visible emissions. I really don't think the pcv line was being sucked much in the position it was in. Perhaps had I elbowed it towards the throat of the carb; I don't know.Apeiron said:Oil consumption shouldn't be any different, the PCV valve is connected to the port on the carb?
Thanks my friend. I really appreciate you. Being nosey now; are you a U.S. citizen living down there? You sound awfully American. :lol:Apeiron said:Ok, they were describing a breather line to the air cleaner then, which is what you already had in the valve cover. Without positive ventilation the crankcase pressure is just bled off through the breathers and makes an oily mess. A PCV port on the carb is just a large manifold vacuum port, as long as you connected the PCV valve to a centrally-located manifold port you'll be fine, and the crankcase gasses will be burned off without making a mess.
Sorry, you certainly speak a level of english which is much broader than formal. Heck, you speak it better than most Americans. :lol:Apeiron said:Nope, no Americans in this household. :wink:
Oh no, not Canadian. Oh wait, I'm picking up the accent now. :lol:Apeiron said:Thanks, turns out us Canadians can speak good English down here where our teeth don't have to chatter with the cold. :wink:
viewtopic.php?p=442090Jay said:Shooter, do you have any photos showing the fuel tank pump access port/panel/hole in your floor?
Thank you!
I don't know much about the stock carb. If you can look at an 86 or early 87, that'll show you. The carb has an automatic choke which probably has a single wire. Between the carb and intake should be a heater block/spacer. It has a pigtail with a 2 healthy wires; one black and on brown with a black plastic connector. This is for a federal carb and not a california carb. california has more since it has an ecm. It might have a wire (solenoid?) to kick the rpm up when a/c is on. You might try posting your question over at http://www.isuzupup.com if you don't get a good response here.86trooperman said:quick question. i just got done carbing my friends troop with a 2.6. we put a stock carb with the vacuum lines and stuff on it. there is a plug for the carb that has 4 wires coming off it. do you know what those 4 wires are for?
Pictures ???86trooperman said:quick question. i just got done carbing my friends troop with a 2.6. we put a stock carb with the vacuum lines and stuff on it. there is a plug for the carb that has 4 wires coming off it. do you know what those 4 wires are for?
