1 - 13 of 13 Posts
Run the 4ze1 until it is warmed up.
Turn it off.
Let it sit for about 15 minutes.
Now, if you loosen the clamp on the fuel line that runs across the top of the common chamber... Should there be any fuel pressure there ?
Seems to me like the pressure should all make it's way back to the tank by then, via the return line, right ?
No, for some reason this engine doesn't work like that. However, let it sit for a couple/few hours and it will relieve it's self but never really fully 0 psi.
Should hold pressure for a long time or you couldn't let it rest for hours / days and have instant start up.
Ah. So I had it backwards. (Nothing new for me. LOL)]
So if I opened up that line in say a half hour, and there were NO pressure there, I might need to check out the injectors for leakage...
I would say that or for some reason the pump isn't holding the pressure. If it isn't the injectors, "they" do make a brass check valve which would be installed inline to hold the fuel between the injectors and fuel source. Normally between 25.00 / 30.00 bucks. Very common item in marine applications.
Ok, now that's interesting.
If I have a problem with this in the future, I'll have to check that out.
Thanks.
Curious why you would need to loosen the fuel line?
Turn it off.
It's usually easier to loosen it before you remove it.
Because I swapped the head gasket.
Jay said:
Ha! You funny guy.
Okay.....why are you needing to remove it?
Ah. Well, well I did my head gasket I opened the gas cap to release pressure from the system. Maybe that's not the correct method, but when I removed the hose attached to the common chamber I didn't get any gasoline spray. It bubbled out a bit but I was ready with a piece of aluminum round stock and plugged it into the hose.
Jay said:
Ha! You funny guy.
I'm going to have to remember that about the gas cap. Great idea !!
Aw shucks gee whiz thanks but I'm sure I'm not the first to think of it.
By the way, didn't want to jack your post re: your shaved head, but I SO wanted to be a smart aleck and say that 16 degrees would be awfully cold on a shaved head and you might want to wear a cap. har har.
1 - 13 of 13 Posts
