90-99 4L30e transmissions have a 5 Pin overdrive case electrical connector and a 4 Pin main case electrical connector. 00-and newer 4L30e transmissions have a 4 Pin overdrive case electrical connector and a 7 Pin (6 used) main case electrical connector. A 2WD 4L30e does not interchange with a 4WD because the tail shafts are different. You can rewire the connectors and use a 00-02 Rodeo/Passport 4L30e but not a 00 and newer Trooper/Axiom 4L30e.
