1 - 3 of 3 Posts
IM LOOKING FOR A TOOL TO REMOVE THE ACCUMULATOR COVER ON MY 2000 RODEO 4X4 IT HAS A SMALL LEAK THE PART IS 5$ TRANNY SHOPS WANT 300$ TO DO THE WORK HAVE THE PART NOW I NEED THE KNOW HOW :)
PM JLEMOND, he can guide you through it without a tool, or Cronk can too. You just need a socket with an extension to get the snap ring out, just be careful as fluid will come pouring out.
You'll be fighting the spring inside that cover - that's the biggest problem.
To remove the cover, you have to press the cover IN to the case a small bit, then remove the snap ring and S L O W L Y allow the cover to exit by itself.
Control of that spring is the biggest problem - but no way is it worth $300.00.
If I was still working, I'd charge no more than $25.00 if you brought the parts in to me.
That would involve replacing the o-ring too - you DO have the o-ring - right?
1 - 3 of 3 Posts
