Well folks, after completing the rebuild on my 2000 Rodeo, I thought all was well. But, then I noticed the TCC lock up was acting weird. From a dead stop (or a really slow speed) once shifting through all of the gears was complete and the first command for lockup was given, it was not normal. It will lock for a moment, unlock for a moment, then lock down solid and stay locked up good. Now, the more confusing part is the lock and unlock at cruising speed is normal. If I mash down the accelerator hard enough to speed up a lot, it will unlock, speed goes up, then it will lock back down solid when I back off the accelerator with no hesitation or crazy B.S. I let this go on, hoping it would go away after a while, but it didn't. After putting about 550 miles on it, I developed a slight leak at the front pump seal.
So, now I've pulled the transmission back out to determine the issue. So far, I've found that the end play on the turbine shaft was out of spec a little. The book calls for .004 - .031, and mine was .042ish. So, not really bad. And I can easily fix that.
Then there was the front pump bushing and the converter hub. They were not getting along at all. The brand new pump bushing was all scored up all the way around, and the converter hub was scored on one side. So, I can only assume the hub was not truly straight. I created a crude set up to try and check the run out on the hub. Here is the video:
So my supplier is getting me a new converter since they promised only .006 of run out. I'll have to install another new bushing of course. I'm also going to try another TCC solenoid just in case. Other than that, I don't know what do here.
