After I bought `98 3,5L Trooper, it had problem with reverse gear - it was engaging on high revs only. All other gears worked like a charm.
Changer the oil+filter. It seemed to make a situation a bit better, since the oil after change became looking not so new after 100-200kms.
One day all front gear dissapeared, but reverse began to work perfectly. Nevertheless, it seems that on neutral car wants to move backwards as well. On D123L it stands stil and kills the engine on higher revs.
I cleaned and checked the range sensor with tester and it seems to be ok - it gives the right signals.
What else could cause the issue? Help, please
