Hey all, I just swapped a used 4jb1 (non-turbo) into an excavator. I want to check if my oil pressure readings are acceptable. I have an analog oil pressure gauge plumbed into the engine. First start of the day with a cold engine and it is about 70psi. Over 15-20 min of use it gradually drops and holds steady at about 20psi. Is this acceptable, or should I look into this? I am running Rotella t4 15w-40 with a carquest/baldwin oil filter. I am in the states so not many mechanics around with experience with these engines.
Thanks,
John
Thanks,
John
