Gotta have some open/box end wrenches, man! Hard to do much without.
Check on Slickdeals.net for the best deals on all kinds of stuff. I have a search saved for "wrench" so lots of sales pop up in my mailbox. This is a great time of year for that, too.
The reason why you want a basic set of combination (open and box ends) wrenches is that they may get into a tighter spot than a Gearwrench, and you can use a "persuader" (i.e. hammer) on them to loosen cranky bolts.
You don't want to beat on the ratcheting Gearwrench, but they do have a great purpose in being able to ratchet in tight spots.
This Kobalt set on sale at Lowes is less than $11.00 and should give you adequate service for what you're doing.
Maybe Santa will drop some wrenches in your Christmas Stocking! Of course, a lump of Coal is gaining in value daily!! Harrr! 😼
Regarding breaking-loose tie rod ends, I worked on a Honda Element early Fall and this tool easily busted loose ball joints and the tie rod ends:
Gearwrench ball joint separator, I was worried that it might not be strong enough for the Element ball joints (they were NASTY), but it popped them like nobody's business. A very well-made tool. It made short work of the tie rod ends as well. Its design is such that it won't damage the grease boots when you're breaking a joint. Which is a nice feature if you've got to bust a joint that was recently replaced, and you don't want to damage anything.
Cheers...........ed
