bought my 95 rodeo last summer... with 144k on it.
at about 150k , the infamous ticking began. (I wasn't aware at the time of purchase, that this particular enguine was WELL KNOWN for developing this issue ardoun 150k+..)..
I've just kept changing my oil, hoping to find a brand of oil that would reduce the ticking. Also been trying different weights of oil, and different types of oil additives available...
Mobile synthetic blend 10W40 high milage formula seemed to quiet things down slightly. Durring this summer I have started running 20W50 (regular petrolium type) to see if heavier weight oil would quite it down. This helped a little bit...
A few months ago. after trying STP, BG, MOA, and several other oil treatments, I tried a silver and black and blue can, of "enguine restore.".... I was about a half a quart low a third the way through a 3000 mile mark so i tried this instead of topping off with oil.... in 5 minuts, I was amazed. My enguine was smooth. no tick to be found. drove it with nearly no ticking whatsoever, through the remainder of that oil change, and continued using it for a few more oil changes... The usefullness of this oil addative, seems to have declined for me however. After about 10,000 miles, the tick has returned, and the enguine-restore oil treatment doesn't seem to help it any.
I'm pushing near 175K on this thing. I really would like to see another 50k out of this motor before it has to be rebuilt/replaced.
Have been meaning to try lucas, and rislone.
Some folks above are talking about something called "seafoam."
I've never heard of this, would be interested in where to aquire it and what it is and what it does.
[EDIT] : I'm pretty sure the ticking, is coming from the lifter/valve train- From the information I have read, and looking at diagrams of the enguine, also taking into consideration that there is no adjustability in the valve-train to makeup for tolerance changes.. it would seem to me, that the ticking is probably the sound of those hydrolic lifter "shims." banging back and forth... as those parts wear down, the space between them becomes larger, resulting in them clicking back and forth. The mechanics I have spoken with about the issue are in agreement... It seems to me, that the reason the "enguine restore" worked, for a little while, was that, it was able to bolster up this gap between parts. Also, heavier weight oil also seems to "fill-the-gap" better than lighter oils. I also ran with 5W50 weight full synthetic at for one change interval, it seemed to provide better protection between worn parts (less noise) while at the same time provided a more freeflowing oil. (noticed lower pressure readings, indicating that the oil flowed easier) Havn't been able to find this weight anywhere in town latally. It was a quaker-state "high perfomance enguine" type synthetic. I mentioned above, that I am currently using 20W50 weight, I only plan on using this through the summer months for experimentation, when cold whether comes back, i'll drop back down to a 5W or 10W winter rating.
